oke
All 21 ST:TNG Secret Codes Revealed
These codes are valid for LX-7 (the last known ROM revision).
These codes may be entered in attract mode OR game mode!
For the Secret Video Mode code, it MUST be entered in game mode for it
to take effect.
All codes are 4 digits in length.
To enter any of these codes, do these steps:
1) Hit BOTH flippers, simultaneously, to clear the code memory
2a) Repeat steps 2b and 2c for each of the four digits, in order:
2b) Repeatedly hit the LEFT flipper the given number of times (for instance,
if the current code digit is 5, hit the left flipper five times) - note that this
may be zero times!
2c) Hit the RIGHT flipper, ONCE, to lock the code digit into memory and
advance to the next digit
3) When done with all four digits, hit the RIGHT flipper, ONCE more, to
activate the code So, for example, the code for 0248 (Secret Video Mode) is
BRLLRLLLLRLLLLLLLLRR (with "B" meaning to hit both flippers simultaneously).
0516 CHANGE RULES AS NEEDED. -DAMMIT
0673 HI TED
1165 HELLO DOC X
1167 THE BORG ARE REAL PARTY ANIMALS (with graphic)
1890 HI ZAP
2135 HIYA SEXY I LOVE YOU (with graphic)
2594 HI DAN
2614 HI BILL
3333 HELLO WORLD
3391 HI TRACEY
0248 Secret Video Mode! (when used in-game it enables Secret Video Mode
instead of Poker With Riker, until end of game. (To get Poker With Riker, get to
the "25 Million Or Shuttle Simulation" mode, then hit the right flipper WHILE
holding in the trigger.) In a multiplayer game, if one player enters the code, it
will not affect other players (they will need to enter the code on their own).
When used in attract mode it just flickers the display and restarts the current
attract mode sequence, without having any other effect.)
4907 MATTHEW C. CORIALE (with graphic) (this is not the MCC of high
score initials fame, that would be Marc Conant)
5949 HI CAB
6969 HI DOHO
1477 HELLO XAQERY I'VE MISSED YOU
8118 SUPER GAME RULES
(feel free to speculate on the relation of this game to Judge Dredd)
8148 HI GEORGE
8556 Sequence of 14 Steve Ritchie games, up to and including ST:TNG!
(with sound and graphic for each game)
9089 HI JASON
9223 HI TEX
9876 GOOD LUCK LED
All of these codes (except for HI JASON, see below) have been tested and
verified on VPinMAME using LX-7 ROM. If you are having trouble entering
codes, please take care to enter them quickly and steadily. If you are too
fast, slow, or inconsistent, the code will not be properly received by the game.
Perhaps there's a bug in handling a second digit of zero, since HI JASON is
the only code that does this. If anyone's curious, these codes are listed at
offset 0xC0E2 in the ROM. Each code is a 16-bit number, big endian, made
up of four 4-bit hex digits, going from left to right. In other words, the codes
can be plainly seen by just visually looking at a hex dump of the ROM! Enjoy!
