Hi JC
I write of something good for testing --- BUT DANGER !!!
I like to use Jumper-Wires to guarantee "from HERE to THERE" IS CONNECTION.
The first test is not very dangerous. Toggle-off the pin and unplug the main power cord. Look in the pin - the transformer - see 25Volt-wire-color-red-yellow running to a fuse-holder (10 Amp Fuse).
See on the transformer the 25Volt-Returning-Wire-color-BLACK ? It is the same wire-color-black You see on one side of the coil on almost any relay. See on the transformer the 25Volt-Returning-Wire-color-BLACK ? Are You 100% sure ?
OK - then (pin is toggled off, main power cord is unplugged) establish a permanent jumper "Transformer-Lug-BLACK to "N-Relay-COIL-side-wire-BLACK-is-soldered-on". With this Jumper-Wire we guarantee "Return-Side HAS connection".
Then plug-in, toggle-on, start a game - play so the N-Relay should pull in (making 10 ? or 100 points ? on the playfield) --- Are we lucky and You get the N-Relay working ? Then the fault must be in "what we have jumpered".
No Luck --- it is getting dangerous - Toggle-off the pin and unplug the main power cord !!!
Look at The "25 Volt-10-Ampere-Fuse" - See the side of the fuse with wire-color-red-yellow coming from the transformer ? THIS SIDE IS FORBIDDEN - NEVER TOUCH, NEVER USE FOR A STARTING POINT FOR JUMPERING --- NEVER !!!
The other side of the fuseholder has wire-color-red-white soldered-on. OK - then (pin is toggled off, main power cord is unplugged) clip-on a Jumper-Wire AT SIDE RED-WHITE and take the other end of the Jumper-Wire into the open - NOT touching metal.
Take another Jumper-Wire (pin is toggled off, main power cord is unplugged) and clip-on at "COIL on N-Relay - side "not-Black" --- take the other end of the Jumper-Wire into the open - NOT touching metal.
Beware - You will use Jumper-Wires with "Power, HOT" 25 VAC. NEVER touch the gator-clips of the Jumper-Wires !!! ONLY hold the insulated wire.
OK - You are ready for the next test --- the very first jumper-wire on the returning side is still in the pin, You have two open ends of Jumper-Wires in the open - NOT touching metal.
Plug-in, toggle-on, start a game --- NOW hold with one hand one Jumper-Wire at the insulated wire and hold the other Jumper-Wire at the insulated wire --- and it is getting interesting: Hold the two gator-clips together for a moment - question: Does the N-Relay fire ?
Because the "pieces of schematics You have shown up to now" do not show the "N-Relay": In my JPG I show the Jumpering for testing "Hundreds-Score-Drum-Coil" ---- but You do testing the "Coil on N-Relay". Greetings Rolf
