(Topic ID: 127739)
LW3 VUK not working
By joekiss
6 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by joekiss
#1 6 years ago
Need some advice where to start. Failed the coil test. Ran the switch test and it def recognized when there was a ball there. I have checked all connections. It just stopped working. Where should I begin?? As always thanks in advance!!
#2 6 years ago
No thoughts?
#3 6 years ago
If the coil won't fire in the coil test, it is most likely a bad transistor. Check Q2 on the PPB board. It is a TIP36C. If it tests ok then check the pre-driver, Q24 on the CPU board. If both those check out ok. It might be the 7402 chip in position 12A on the CPU board. Hope this helps.
#4 6 years ago
I would first make sure there is power to the coil and then do as action76 suggested.
#5 6 years ago
How do I check power to the coil?? Is it possible the coil itself is shot?
#6 6 years ago
Quoted from joekiss:
To test the supply voltage, put your red lead on one of the coil leads and the black lead on ground. Meter set on DC 100 volt scale and game on.
#7 6 years ago
Fixed!!! Bad connection!! As always thanks!!!
