Anyone have any literature on how adjust/fix the issue?
Thank You,
Pete
does it fall when you turn the power off? Or does it stay stuck? If it falls when you turn the power off it is probably electrical problem. If it stays up after you turn the power off then it is a mechanical issue it is probably hanging up on something or plunger and or coil stop is magnetized.
Read on a site that it's a failed diode on the coil. Make sure both ends are soldered on the coil lugs
