I got a LW3 that was reimported and the flipper mechs were just destroyed and had mis matched coils and the whole works. I ordered all the replacement parts from Marco/pinball life, using part numbers from the manual. I replaced the following:
Flippers
Flipper bats
Bushings
Coils
Coil stops
Coil sleeves
Return springs
Return spring brackets.
After rebuild they work just fine however if i set the flippers on the play field markers in the hold position the flippers won't even achieve enough angle to hold the ball? its like the flipper travel isn't enough. I double checked everything and all seems to work right as it should but there is just no travel?If i manipulate the flipper mech by hand everything feels fine but still not enough travel. I am stumped anyone have any ideas.
