(Topic ID: 99624)
LW3 Display ROMS
By CadillacMusic
6 years ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by viperrwk
#1 6 years ago
Whee, this morning I took a perfectly working LW3, and broke it. Not sure how, exactly. We have a JP that's been waiting for boards, so I figured I'd swap out the cpu and display boards from the LW3 and pop it in there. For some reason, it didn't seem to be working. I'd get a roar, but no further sound, and the game would turn off the lights and that'd be it. So I shrugged, and popped the boards back in the LW3 to make sure it wasn't the boards. Well, the CPU is fine, but apparently my display board just up and died. I've switched out and flipped every cable, checked the roms twice, and measured the 5 volts (4.7, not great, but it was working fine with that voltage before). It's gotta be the board. I've got a south park and two RCTs in house with working display boards, but they all have only one socket for the display ROM. Can you combine the two roms into one in any way? Or am I stuck trying to find a working data east one?
#2 6 years ago
Yes, you can combine the ROMs to a single image. I've got the image here, or you can just double it up and program it on a single 27c040 for LW3. Some shipped with a single chip, it's just a jumper change...
Not a lot of chips on that display controller to test. Is the processor running? Activity on the data/address lines of the proc and ram chip? Any burnt components?
#3 6 years ago
Woo, thank you. Do you just copy the text from rom 1 and paste it after the text from rom 0?
I'm gonna troubleshoot the display controller after I am sure it's not the cpu that's failed somehow. Everything Data East is not behaving for me today. I took the cpu from batman, which was also running, and put it in LW3, and it froze up with leds indicating a bad PIA. I'm cursed or something.
Edit: It also explains why it didn't work in JP, as the jumpers were probably not right.
#4 6 years ago
Hmm, tried to combine the two roms, and got nothing on the DMD still. Would you mind linking to the image you have, or sending a copy to cadillacmusic3950@gmail.com ? That'd be incredibly helpful.
#5 6 years ago
copy /b rom1 + rom2 rom3
I'll send the binary, easier that way.
#6 6 years ago
Thanks for the binary. Most awesome of you. Weird thing is now happening with that ROM: The display board clearly boots, and displays the version number, but keeps resetting, just blinking that over and over. It's a known good display board out of a south park. The same thing seems to happen with the south park rom in it. Works fine with the SP ROM in the SP itself. Does having a non-matching CPU version affect it at all?
#7 6 years ago
Quoted from CadillacMusic:
Thanks for the binary. Most awesome of you. Weird thing is now happening with that ROM: The display board clearly boots, and displays the version number, but keeps resetting, just blinking that over and over. It's a known good display board out of a South Park. The same thing seems to happen with the South Park rom in it. Works fine with the SP ROM in the SP itself. Does having a non-matching CPU version affect it at all?
Yes. Major rev of CPU and display ROMs need to match but minor rev does not. As long as both are version 2.x it should work.
viperrwk
#8 6 years ago
Should have also linked to this for future searchers:
http://www.pinwiki.com/wiki/index.php?title=Data_East/Sega#128x32_.28Regular_DMD.29_Issues
Two ROMs in, R11 in, one ROM in, R11 out.
viperrwk
$ 17.50
Playfield - Plastics
PinSound
€ 95.00
FlipperLED
Professor Pinball
Metal-Mods
$ 12.50
Gweem's Mods
Arcade Upkeep
$ 99.00
Arcade Upkeep
$ 50.00
$ 27.00
