New! Dark mode!
(Topic ID: 124547)
LW3 Beacon won't stop spinning. Any ideas?
By action76
5 years ago
  • 14 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by snyper2099
#1 5 years ago
I picked up a LW3 with a few problem I have been working through. One that has me stumped is that the topper beacon spins continuously from the second it's powered on. I changed Q25, which I believe controls the beacon, because it tested bad. I thought that would fix it but it didn't. The pre-driver tests fine, so I am not sure where to go from here. I guess it could be a TTL chip or PIA? Anybody have this problem before or know how to fix it?
Also, it had a pop bumper stuck on and melted the coil. I replaced the coil and the Q9 and the pre-driver which is a 2N4401. I did not have a 2N4401 so I used a 2N2222A because I read somewhere they were compatible. Well the PB coil does not lock on now but it will not fire at all. Do you think the sub transistor I used would be the problem?
Thanks.
#2 5 years ago
probably riggs was driving last.
#3 5 years ago
Pre driver 2N4401 can test good but still be bad... swap it out first. They are like $1. I would order 10 of them since they fail ALL THE TIME. In pinball, they are more like fuses than transistors.
On the other question... I would swap a known working 2N4401 from another place on the MPU to test your theory, if you don't have a new one readily available.
2n2222a? I've never tried one of those in a pinball. It's not identical but should be ok... nope, legs don't match!
#4 5 years ago
Quoted from action76:
While the spec's are similar the packaging is completely different. So even if it might work I would guess you've got it wired incorrectly. 2N4401 is 1-emitter, 2-base and 3-collector. 2N2222A is 1-base, 2-collector and 3-emitter.
Get the correct transistor and try again.
#5 5 years ago
Looks like you would have to mount it backwards for a 2N2222a to work. Good to know this. But,
I would just use the intended part as terryb suggested, not "cram" something like that in there.
#6 5 years ago
Backwards wouldn't work either (that would put the base on the collector and the collector on the base).
OP: Do not ever use a different transistor unless you are positive it is a valid replacement. You not only risk the transistor going up in smoke, but also damaging other components.
#7 5 years ago
well, assuming you twisted two legs to crossover as well... that's what I meant. I would never try to hack that part in there is all I was saying. I fixed my posts.
#8 5 years ago
Wow! I thought I checked that they were both EBC. I guess I read it wrong. I will try swapping that out with the right part and try again. Thanks guys. I'll report back when I try these suggestions.
#9 5 years ago
Update: I replaced the wrong transistor with the correct one and it did not make any difference. I also changed the pre-driver on the beacon just to make sure and it did not make any difference either. A friend helped me track it down and now it looks like a logic issue. I am going to swap out one of the 7402 chips and see if that fixes the pop bumper. I am not sure if that chip has anything to do with the beacon though.
#10 5 years ago
PIA on MPU drives the 7402's, which in turn drive the pre-drive trans, which in turn, drive the main trans. Usually a 7402 drives more than one device/transistor. It is possible for just one leg to short on a 7402.
#11 5 years ago
I'd leave the light always spinning. That's not a problem, that's a feature.
#12 5 years ago
Quoted from snyper2099:
Best I can tell, the chip is made up of 4 NOR gates and each one controls a coil. So it's possible that just one gate is bad and the other 3 are fine, I think.
#13 5 years ago
Well, the new 7402 chip fixed the non firing PB. Still not sure about the beacon yet though.
#14 5 years ago
Well, it could be the 7402 that runs the beacon. Probably a different one.
2,500 (OBO)
Magnolia, TX
2,200 (OBO)
Charlton, MA
Metal-Mods
Arcade Upkeep
$ 27.00
PinSound
$ 17.50
Playfield - Plastics
Professor Pinball
