I’m stumped on this TZ issue.
Lower right flipper is not firing. Buttons are recognized in switch test. Neither the power nor the hold seems to work in flipper coil test, but all other flippers work completely.
Upper right flipper fires when hitting button and in coil test. I Swapped the coil in the non-working flipper for a new one - it does not work either.
I Changed the fuse 906 (lower left of fuse block on fliptronics board) which is for this flipper. No dice.
So where do I test next? The Fliptronics transistor? Q4 (I think?). This has got to be a simple issue. Not sure where to poke next. I don’t believe Wiring is an issue; this flipper died in the middle of a game. The only thing I remember is hearing an unusual buzz from the flipper a few times (when flipping) before it finally died
