Quoted from LTG:HaHa. Too funny. Yup new stuff never fails prematurely or arrives bad.
Have you checked anything ?
Grab a meter. AC getting to driver board ? AC getting off board to bulb sockets ? Try and find where it stops and the fix gets easier.
Could be burned transformer connector, a break for power to board, board, or if power leaving board then check for breaks in wiring to sockets, sockets, bubls good ?
Narrow down your search. You'll be glad you did.
Ok LLoyd, I took your advice. Please read below regarding my situation and maybe it will help the original poster as well.
I have an Indiana Jones Williams. I just replace the original Power Driver Board as well as the Fliptronics Board with New Rotten Dog Boards.
With the new Rottendog Power Drive Board everything works on the game except the lower back box lights. Strange thing is, on my old original Power Driver board the lower back box lights also did not work.
Here's what I have done to try and locate the issue:
- I have confirm the lower backbox string of lights is working via a 9 volt battery test. All lights light up so we know it's not an issue with the string of lights.
- I have confirmed that there is power coming in through J115 at the #5 pin and the #10 pin. I have metered the back of the J115 connector as well as on the front of the J115 connector and I have power on both the front and rear of the connector.
- I have confirmed the F107 fuse is good which feeds the J120-5 and J120-10 pins.
There is no power coming from J120-5 and J120-10 (Green String). There is power to all other strings on J120 and J121. The Yellow, Orange, Brown and Violet strings all have power and all strings work as expected.
The only thing I can think of is there is an issue with the Q16 on the new Rottendog Board. How do I actually test Q16 to see it the problem is truely there?
What I find very odd is that the same issue existed on my old original board. How could you have the same issue on two boards made 25 years apart?
Could there be an issue with the power coming off the transformer somehow overloading only Q16 and causing it to fail or is this just a case of unusual coincidence?
Any additional help would be appreciated. Thanks.
QSS
