The lower left flipper will stay energized at times. Then release if I hit the button again or release if I power off
If the upper is not effected would this rule out the transistor?
( I replaced the coil diode, coil stop, sleeve. )
I thought after I replaced the diode ( a day ago )it solved it but no such luck. Could it be one of the giant caps? ( see photo)
Just want to try everything I can before replacing a tip on the board
