Hello,
I recently replaced all of the playfield lights with LED bulbs on my Bally Spy Hunter. All of the lights have been working great for weeks until the other day when one of them went out.
It's a bulb that is seated into a twist knob thing (not sure the correct term) which is connected to the lower feature lite board. I've tried changing the bulb but no dice. I also moved one of the known working twist knobs with a known working bulb into the spot that I'm having issues with and no dice there either. I cleaned the surface of the contact area around the hole with rubbing alcohol, but it also had no effect.
This leads me to think that there might be a problem with the board or perhaps the connectivity around the hole that the twist knob thing makes contact with.
Has anyone had any experience with these Bally feature lite boards or had a similar issue? Anyone have any ideas on how I might fix this?
I've attached some pictures below.
ATAX
InkedSpy Hunter Light Board 2_LI (resized).jpgInkedSpy Hunter Light Board 3_LI (resized).jpgInkedSpy Hunter Light Board 4_LI (resized).jpgSpy Hunter Light Board 3 (resized).jpg
