Quoted from Geertsen:
I am getting the following values. Between 1/9 121v. 8/10 3.22v. 4/10 32.6v.[quoted image]
in your photo, (the bottom of) your transformer is "tapped" for 220v
look at the schematic
MarkG provided (there should be one inside the game as well)
on the line side of your transformer:
you will have to REMOVE the tie between lugs 3&5 , MOVE the yellow (white neutral wire) from lug 9 -to- lug 5 ; JUMPER 5&7 together , JUMPER 1&3 together (lug 9 is unused)
on your load side:
every thing looks fine (it isn't "high tapped" there)
check the value of that input fuse it [email protected]@K's like a 15 or 20 Amp fuse the placard says an 8Amp fuse is required
with all fuses removed except the input fuse near transformer, check the voltages to ensure they are correct
check the values of the other fuses
& hope to hear from you soon
