The motor in the back box of my hurricane pinball That spins the big disc is super loud... short of replacing it would w/d 40 or some other sort of lubricant help?
Dont use that, use some alcohol based cleaning spray for cleaning. What kind of bearings does it have? is it nylon or brass bearings?
Nylon: use lithium based grease.
Brass: ordinary motor oil. just one drop is enough.
Quoted from TheDude:Nylon: use lithium based grease.
+1 Or 3 in 1 oil for brass fittings.
WD40 is bad... WD stands for Water Displacement fromula 40. Great to clean or loosen things. Lousy for long lasting lubrication. As stated above by the dude... Lithium grease for Nylon. 3 in 1 oil is best for brass.
This page was printed from https://pinside.com/pinball/forum/topic/loud-motor-will-oiling-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
