Thanks, Mark. I played around with #39 and found that it worked intermittently. Went ahead and replaced it and the new switch works 100%. Going to try and do that with #25 as well but it's a bear to get at. It's the sword ramp entrance switch and if I remember correctly I've got to take that ramp off to even get to that one.
I recognized the "row" correlation on those 4 switches as well. Digging a little deeper, I've now found that switch #13 is not working either. It's on that same row as well so now there are 5 switches on that row that are not functioning. Again, I jumped power to that switch from a working switch and it worked so I know it's not a bad switch. None of the "bad" switches are optos.
Typically I would think there's a board component (transistor?) that's bad. However, the other two switches on that row, #29 & #37 are working. There should be another on that row, #5, center coin slot. However, my machine only has two coin slots which are switches #4 & #6. There is no #5 on my machine. Does anyone know if a transistor can be partially bad, letting some switches work but not others?
