Quoted from StevenP:If you'd like a more reasoned critique: The color imbalance between the 2 slings takes away from the overall art/theme IMO. And there is NO place for blue in this game--totally goes against the colors/artwork/feel. The POTD area should be green, consistent with the artwork. Yellow byt he center and right ramps does help them pop. (Of course, I used colored bulbs and not garish LEDs.)
Exactly. I was offering a criticism in a humorous way, but Rob took it too seriously and insulted me.
There's no reason for the lower left side to be green...it monochromes out all the natural colors and skintones of the characters. Merry and Pippen are not green characters. There's no reason for the Fellowship inserts to be all different colors...the Fellowship is a singular concept, and therefore having them all be white makes sense.
I'm not against re-coloring an insert here or there...for instance, on my No Good Gofers I made all the "Drive" inserts green. It works as a singular color code and makes sense w/ the golf theme.
LEDs aren't exactly the problem, it's using them in a garish and colorblind way that works against the game. As for LOTR, it just doesn't look great with LEDs, even tastefully colored. The full range of fading FX that the insert lights do look butter-smooth with incandescents, yet choppy and strobey with LEDs. The only LEDs in my LOTR are warm whites in the spotlights, and in the flasher socket behind the ring. LEDs bounce off the silver spotlight insides nicely, and give you more light spread on the playfield. The inserts are already bright enough and like I said, you lose the smooth fades with LEDs.
