I've got a LOTR that has a broken shire scoop ramp plastic (the mostly clear plastic that is riveted to the metal scoop). I've actually went thru two of these now (it's a machine on location that gets alot of play). The only way to get this plastic is to buy the whole plastic set which I've already done once and I'm not going to do again.
Does anyone have one of these available or has someone made a replacement that I could use instead? Something stronger than the original would be ideal so I don't have to replace it again.
