New question - I tried to install a replacement post for the ring ramp which I ordered from PBL. Something must be bent out of shape, since I absolutely could not get the bulkier post to fit into the area. In the end I put the old post back, but I'm worried I should do something about it soon since there's some very noticeable marks. I'll take some pictures next time to see if anyone has ideas. Are there any creative ways to protect that edge of the ramp besides a bulkier/new post?
UPDATE: A few new questions. I'll probably have more to ask soon which I'll place above this update. ANYTHING BELOW IS ALREADY RESOLVED. Many thanks!
I have the original Lord of the Rings (Stern from December 2003) here with me. My current Display/Game version is all the way back at CPU 4.10 and Display 4.04. I'm wondering exactly what I'll need to bring this machine up to date with the 10.00 game rom. I know I'll need the 10.00 U5 Display Controller and U210 CPU Game Rom's for sure and I understand the process of updating these two.
After some reading, I'm concerned as to whether my U7 Sound Rom needs to be updated to 1.01 (or if it is already 1.01), and whether my WhiteStar OS needs to be flashed to meet these newer Rom versions as mentioned in the Stern SB 157. (http://www.sternpinball.com/upload/downloads/sb157.pdf) There isn't a lot of information out there on this from what I can tell, but since my machine is on the older side for LOTR I wanted to make sure this isn't going to be a problem. Did any units even ship without a 1.01 U7? Honestly, I'm not fully understanding the Whitestar sound OS either and what this service bulletin really refers to!
Is my best bet to start by just installing the 10.00 Display and Game Rom's and seeing if everything works properly? If there are sound issues after those are installed, should I re-flash a 1.01 U7 chip and see if that helps or try the Whitestar OS boot flash first?
Also, I just started having trouble with my ring spinner today. It seems the side near the trigger has become slightly bent, causing it to lodge itself in the hole it sits on. It sits horizontally once stuck, so it can't be triggered and needs to be pulled out of the hole. I tried to straighten out the area that needs to be adjusted with pliars, but with it still attached it was just too small a section to properly bend without more leverage. As long as it doesn't get roughly pushed towards that hole, it's spinning perfectly but as it's already happened twice I'm guessing it will be recurring. What's the process for removing, adjusting, and then re-inserting this spinner?
My last question is about my ring magnet, and how to begin repairing it. It hasn't been functional for years, but from my understanding it's likely just fuse F20 might be blown. Is there anyway to easily diagnose the issue, or should I just try a new 4 amp SloBlo Fuse in F20 and see if that solves it? I've also heard some are using 5 amp SB fuses in this slot as Stern said it would be okay, and may keep it from blowing so easily. If the fuse is not the problem, what are the next steps I should take to repairing this feature?
Really appreciate any and all help! I'm very new to this and having a difficult time wrapping my head around everything!
Post edited by ElendilAndurilz: Many questions answered, a few newer questions!
