(Topic ID: 14018)
LOTR - rings led's
By Mando
  • 22 posts
  • 9 Pinsiders participating
  • Latest reply 1 year ago by paynemic
Two of the three LEDs For the elves aren't working. On will flicker the other is doa. All the other ones(dwarfs and men) work fine. Not really worth replacing the entire unit has anyone successfully fixed individual led's ? Maybe just touch up the solder ? Anynwayntonget a replacement led in casentheynare just dead?
You can solder in new LEDs but that board, how much is it? You sure it's not a wiring problem?
I've had the same problem on a LOTR and an ID4. When I change the LED, it stops working after a bit. I put an incandescent bulb in and all is well. Sorry, I don't know why.
Quoted from dirtrider:
I think he is referring to the LED ring at the bottom of the playfield. It's a factory LED board, not a light bulb. Your issue is something separate. Usually it means you need to rebend the pins on your LED so they make better contact in the socket (or you used cheapo LEDs).
2 of the 3 elves leds are out in mine also. I would love to know how to fix it. I cant justify spending the $80 for a new board but probably will sooner or later.
Yes I have replaced a white elf LED that was not working on the 19LED board on my LOTR.
They are just standard LED components that you can buy at an electronics shop. I bought a pack of assorted ones and just soldered in a new white one. You may have trouble matching the exact colour. Check with a meter to see if you have any voltage across the LED on the circuit board when it is supposed to be lit. If you have voltage just replace the LED, if there is no voltage, reseat the board connector first, otherwise you probably have a fault on one of the chips on the board. If one LED is flickering, try reflowing the solder on the LED affected.
Ahh ok cool so just an led from radio shack then? One of the two that is out is flickering. I need to invest in a multimeter I will try reflowing solder easy enough.
Quoted from markmon:
Ohhh... Thanks for the correction. I've tried the bending of contacts on the socket AND the bulb. I only get the cointaker bulbs. It just can happen on one socket per game...tried different bulbs, seems like they burn out? I'm puzzled.
Might be the socket does a regular bulb work?
Board seems to be sending current led just not lighting up so...resolver or new led. How difficulty is replacing the led seem like a fairly precise soldering job is required?
Looks a little tight in there but you can do it!
Yea shouldnt be too bad. I guess once I heat up the solder the old LED's should come right out?
It would be a little tricky because you'd have to heat both leads at once and not bump anything else. Perhaps you can snip the led off from the topside then heat each lead individually and pull them out the top
Get a solder sucker or some wick and that will help.
Quoted from Mando:
A regular bulb works fine & that's what I have in there.
I had no problems unsoldering the defective LED. Just push the LED to one side as you melt the solder on the other side and the first wire will pull out through the board. The LED will then pull out completely as you melt the solder on the other pad. Those solder pads are tiny so be careful not to bridge any traces when you do this. Make sure that you fit the LED the correct way round, there normally is a "flat" on one side of the component, or else look inside the LED and align it so that it looks the same. Don't take too long soldering in the new one as these components can be damaged by too much heat.
Cool thanks, DirtRider in your case try cleaning the contacts on your socket and bending the pins on the LED should work.
Wohoo I did it! Had to do it twice first LED turned out to be yellow even though it looked white Its a little brighter than the stock ones but it does the trick. I frosted it a little to make it less bright
5 months later
#19 11 years ago
Anyone know what the voltage should show across the LED's ? My three elf light are all out and would love to just test it with a meter before I go desoldering anything.
#20 11 years ago
If recall it was 2.5 just test a working one. Just put in new LEDs it will work
#21 11 years ago
Duh, test a working one... funny how the obvious thing never occurred to me. Will do!
10 years later
#22 1 year ago
Putting this here for future reference:
I had white LEDs go out on the rings disk board. I saw some threads about replacing them. But the links were outdated. I bought these in frosted:
https://smile.amazon.com/gp/aw/d/B09B9DP4M6
They worked great. Note that the long leg went in the circle pad side. They were bright but not overwhelming.
The old leds desoldered easily. It was a simple fix and cost like $5. The boards seemed to be sold out everywhere.
10,000 (OBO)
Deer Park, NY
$ 12.95
10,400 (Firm)
Juneau, WI
$ 5.00
Pinball Fuzz
€ 7.50
Pin-Decals
$ 41.00
RamMods
RGP Models
€ 7.50
$ 12.00
PinWorlds
$ 79.95
Pinball Life
$ 130.00
Dijohn
$ 1.00
Pinball Alley
$ 200.00
Professor Pinball
$ 8.99
Mitchell Lighting
PinWorlds
$ 18.95
$ 29.00
Pinball Photos LLC
YouBentMyWookie
9,500
Anderson, SC
9,000 (Firm)
Ronkonkoma, NY
RamMods
WilliPinball Mods
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/lotr-rings-leds and we tried optimising it for printing. Some page elements may have been deliberately hidden.
