I searched the forum and didn't find an answer for the problem i am having.
Have the machine for weeks now and the magnet/ring shot worked fine all this time.
One week ago it started to not register the shot so the magnet doesn't activate. For example, if i have ring mode lit, the first 3 or 4 shots the ball or falls to the pf or goes straight through the ring to the back then to the path. The magnet doesn't fire. There are sometimes that works, but rarely.
In the switch test everything works: the spinner, the optos in the ring and the back switch.
The magnet also works fine in the coil test.
So, everything passes the tests but in the game it doesn't work properly, where do i start?
Anyone had this same problem? Any suggestions?
thnks in advance
