Ballrog has a super-bright red 24V double led strip inside that's connected to the standard flasher.
The right tower has a standard 12V led strip and a double blue 24V led strip that's connected to the coil.
Quoted from lb1:The left side of the the center ramp entrance got hit pretty bad. The metal had mushroomed. I grinded the whole thing and drilled two holes. Once the ramp comes back from plating I might add some rubber protector.
Stern had released service bulletin 154 to prevent this from happening, looking at your ramp and playfield pictures, it appears this upgrade kit was never installed. http://www.sternpinball.com/upload/downloads/sb154.pdf
The post upgrade kit Pinball Life has is a superior to the one Stern released in the service bulletin, and I would highly recommend getting this. http://www.pinballlife.com/index.php?p=product&id=1045
More fine tuning…
The small cabinet hardware pieces that keep the playfield centered when lowered made it hard to have the playfield all the way down. I had to push and I first couldn’t figure out what was going on. I thought maybe I had a wire or cable stuck somewhere in the back. It turns out that with the extra felt on the side, the clearance is tight. I decided to turn these upside down. Problem solved.
Second, the rear wire harnesses. It always bugs me to have the back panel rub against the wiring, particularly with the LOTR, which has quite a bit going on in the back. I used some of these guys to make sure that the hardness are right against the cabinet back wall - https://www.amazon.com/Pro-Tie-B1PSSM100-Adhesive-100-Pack/dp/B005LTJ4PW/ref=sr_1_2
Flipper area lighting. Brass bar with a small RGB led strip and some zip ties. I went for purple but can easily change the color. What do you guys think?
I added a couple of small pieces of Mylar to avoid damage to the ball through drop area. Hard to see with the purple lighting but it’s there.
Quoted from Pin_Guy:Stern had released service bulletin 154 to prevent this from happening, looking at your ramp and playfield pictures, it appears this upgrade kit was never installed. http://www.sternpinball.com/upload/downloads/sb154.pdf
That's good to know. Thanks for the heads-up.
Are there any options to get a reinforced Palantir target frame? Same as the slot machine target on TZ?
Quoted from Razorbak86:I love a lot of the small details, like the brass acorn nuts holding the front plastic to the Shire! Very nice.
BTW, I made this change as much for cosmetic reason as to be able to replace the plastic more easily if it broke, or add a plastic protector. Rivets are good for ramps, not so much there.
Quoted from lb1:BTW, I made this change as much for cosmetic reason as to be able to replace the plastic more easily if it broke, or add a plastic protector. Rivets are good for ramps, not so much there.
Agreed. I think it's brilliant, from both a cosmetic and maintenance perspective. In fact, I just bought some acorn nuts at the hardware store this week to do the exact same thing. Thanks for the inspiration!
Quoted from Razorbak86:Agreed. I think it's brilliant, from both a cosmetic and maintenance perspective. In fact, I just bought some acorn nuts at the hardware store this week to do the exact same thing. Thanks for the inspiration!
You'll need to find machine screws with the smallest head you can find that fits to avoid having the screw heads interfere with the ball path.
I should have taken pictures. I had to try a few to get the right fit.
This page was printed from https://pinside.com/pinball/forum/topic/lotr-refresh/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
