Hi,
I need to swap out the Q22 balrog transistor in my LOTR machine, what's the best transistor to replace this with? Would a IRL540 be o.k. ?
The picture is what's fitted currently.
Thanks.
O.k. I didn't realise that code was the identity of the transistor.
NOOB with transistors, tested it and it is dead, first time I have changed one.
Thanks for the help.
Quoted from adbex1:NOOB with transistors, tested it and it is dead, first time I have changed one.
You may want to have a board repair guy replace this for you if you aren't experience in removing these from a double layered circuit board.
