Hey guys - trying to do the same mod that ATOMICBOY did for his POTD. Was going to just purchase the mod, but I really like the idea of the figures individually turning on and off with 4 game lights for the POTD instead of staying for the whole ball play.
That said, I don't have a great deal of electronics experience or dealing with LEDs so I was hoping you all could answer some questions for me and help me make this mod myself. Here are my questions:
1. IMG_3835.JPG These are the LED's I plan on using. They are 5mm green. Do I need to use a resistor in in line with them, or am I ok since I am tapping off of the 4 lights already?
2. The original 4 lights have one common ground lead. Should I hook these LEDs up the same way with one ground lead in series between them? I assume so.
3. I really don't want to splice the connections. I know I can probably shove real hard and push another wire into the connector, but I know it will be a PITA, a tight fit, and might mess up the connections there already. What I would like to do if they are available, is to get a connector that I can insert the wires from the LEDs into and then put in between the stock connector. Basically a connector with one female and one male side so I can put it in between the connector below and piggy back off of it. Hope that makes sense.
Thanks in advance for any help.
