Hoping someone might have these plastics I can buy from them: 00 and 20. Also wouldn't mind a 37, since mine had to be repaired with super glue.
Do you have pictures or descriptions of these plastics? I can check to see if I have them, but for me, it's easier to verify with pics
Chris
I searched long and hard for the shire plastic with no luck. I finally made my own reproduction after gluing it so many times that it basically became unrepairable. I used lexan for the new one which is a bit stronger than the original butyrate plastic. I used a transparent inkjet printable decal to get the image onto the plastic. If I could do it over again I should have used a white backed decal instead.
Cool, thanks a lot. I really, really want the 20 one (the one near the Shire), since I recently realized that the one on mine isn't even an original, someone just cut out their own, with no decal, it looks pretty terrible.
Is the 20 the vertical one in front of the shire? That's the one I was referring to in the post above so disregard me calling it 37. It gets pretty beat up from getting smacked by balls coming out of the POTD.
I'm also looking for -37 and 00 (the two plastics that sit underneath the ring to deflect balls that don't go through the ring). I'll play without them before buying an entire plastic kit but would be nice to find someone willing to sell these. Thanks!
I can scan my piece and try to make templates. It might only be a good option for the -37. Let me know if you think it is worth the effort.
If you don't want to buy the plastic sets, I recommend getting some lexan and using a fine-toothed jigsaw blade and cutting your own. For the green print, scan the plastic and then print it onto a decal.
Quoted from drshaw:37 is just red right? and 00 is just clear plastic that sits on top of 37?
Not sure on the number, but one of the pieces is red and not really seen. It just covers the ^ (point) at the top of the playfield where the ball either goes towards the tower or the lanes. The clear insert (37) is there for the balls that are rejected from the ring whether it is due to bad shots or when mode start is not lit.
20 is the shire plastic and is used to cover up the left VUK.
I (hopefully) can work on doing scans this weekend and will post them up in a new thread call LOTR plastic scans. That should work.
This page was printed from https://pinside.com/pinball/forum/topic/lotr-looking-for-a-couple-plastics and we tried optimising it for printing. Some page elements may have been deliberately hidden.
