I Found an older post asking about replacing flipper transistors Q15 &Q
16 with beefier transistors too avoid blowing fuse. Question was answerd by pinsider stevenP.Steven sounded like he new what he was talking about.He also commented about the LOTR coils heating up and weakening.He also added that If you had the LOTR L.E. that you did not need to get the pinball life coil upgrade. I have a (LOTR L.E.) and have not noticed a problem.I tried to PM Steven to confirm his source but he has disabled his Pinside mail. I really do not want to order the upgrade cause I suck at tech stuff. Can any one verify if stevenP is correct ie: LOTR L.E. coils can handle the heat problem and do not suffer the same problem as The original LOTR. Damm long messege to answer a Yes or No question Thanks Rob
