I recently was having issues with my balrog not working correctly, so I went through it all and decided it was just time to replace everything associated with it. I replaced the coupler and the motor. Once I put it back together, the issue is still there. It will not open and close properly, and seems to want to go in a 360 once it closes the lane up. I thought maybe it was the switches, but they seem to be fine. Now I am coming aware of thing called the relay board, which I had no idea what that was before. I went into the test coil menu, and selected to run the balrog relay motor, #20. Balrog didnt do anything, and not sure if he is supposed to or not. Could thje relay board have gone bad, and how do I check this? When i ran the test, i heard some sounds coming from the board, but now I dont hear anything. Is there a fuse that controls this? Thanks so much for all the help. I just dumped almost 200 bucks in the motor and coupler, and still not working. I have a DMM, but not real sure how to use it, so be kind. Thanks
