Greetings. I'm having trouble repairing my lotr. A while go, the autoplunger became stuck activated. As soon as the game is turned on, the autoplunger activates and causes fuse F21 to blow in short order. I replaced the solenoid and replaced transistor Q2, but the problem persists. All switches (except for Balrog hit and Balrog open/closed) show as open. Switch 2 works correctly. Disconnecting the Balrog does not stop the problem.
Does anyone have any ideas of what else it could be that's causing the problem? Thanks in advance.
