What I have done so far is that I have checked all the switches and they activated ok in the switch test.
What I did today:
- replaced ballthrough opto-boards
- exchanged the coil for the autoplunger
- renewed a bent switch back plate for the palantir switch
Once I started the game, the autoplunger was firing all the time and in the switch
test palantir was also activated.
I bent the palantir switch leafs so that the would not touch each other and also tried
to bend the diode and the wires going to the switch. I also readjusted the shooter lane
switch.
This stopped the automatic firing, but the automatic wiring still occurs during the game,
now more often than before.
I am think that there is something fishy going on with the palantir switch and I will take
pictures for you to have a look at. I will take some pictures of the shooter lane switch
as well.
Attached is a picture of active switches in the test - is it normal that Balrog Hit is activated
there?
Thanks again for all tips!
