(Topic ID: 280527)
Lost World: Wiring a Power Switch
By Knxwledge
  • 16 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Quench
#1 3 years ago
I bought a Lost World, and the power switch was missing. I've attempted twice now to wire it and very clearly I don't know what I'm doing. Am I using the right type of switch? Any help appreciated. Attached down below is schematics, along with the first attempt I made at wiring it up (which lead to smoke coming off the butt connected wires of the load side of the line filter lol).
20201028_190150 (resized).jpg20201028_190150 (resized).jpg20201028_194629 (resized).jpg20201028_194629 (resized).jpg20201028_194633 (resized).jpg20201028_194633 (resized).jpg
#3 3 years ago
This is for wall plugs, which I believe I have wired in correctly (I bought a whole new cord, and I just soldered ground, hot and neutral onto the line filter the same way as the old cord). What I need is assistance on the On/Off switch wiring
#4 3 years ago
Quoted from Knxwledge:
Let me know if you need me to check continuity or polarity.
16039416688096266401268261023437 (resized).jpg16039416688096266401268261023437 (resized).jpg
#5 3 years ago
Quoted from iamdrunker:
Let me know if you need me to check continuity or polarity. [quoted image]
I bought a 2-prong (or 2-wire) switch, and that's why it's not working. Thank you very much, I will most likely buy a replacement line filter as well since there's a high chance I blew it up
#7 3 years ago
It's a single throw, Dbl pole switch. like you're schematic shows. If I'm reading that right.
#8 3 years ago
I had it wired like this:
1 wire of the switch, both neutral wires (one for the service switch, one for the line filter), and the blue wire
1 wire of the switch, both hot wires (one for the service switch, one for the line filter), and the yellow wire
Here's the switch I'm currently using: https://www.amazon.com/gp/product/B01IYKSLCG/ref=ppx_yo_dt_b_asin_title_o00_s00
#10 3 years ago
Quoted from Quench:
That switch has 3 positions (ON-OFF-ON).
You want a switch with 2 positions (ON-ON) where you don't use the second ON position - one of these will do:
amazon.com link »
amazon.com link »
amazon.com link »
Thank you. Then how do I hook up the wires? Same as the factory one (in the picture posted by iamdrunker)?
#11 3 years ago
Please be very careful here, the way you wired that first switch would have blown the house fuse.
iamdrunker has his power switch wired to match factory, but it only shows part of the story. If other wiring on your game has been incorrectly wired (i.e. your power cable/plug or the connections to the EMI filter) you could have issues.
Put some heatshrink tubing over the power switch connections so you don't accidentally touch the connections and get zapped.
Essentially the wire from the active (hot) pin on the power plug must reach the final destination of J2 pin 6 on the rectifier board.
J2 pin 7 is the neutral (return) wire to your power plugs neutral pin.
If you're not aware, the wire colors are coded on the schematics:
#12 3 years ago
Quoted from Quench:
Here's how my EMI filter's wired. The Blue wire coming off the fliter is crimped to the black wire that leads to the switch, and the Brown wire coming off the filter is crimped to the white wire that leads to the switch.
20201029_142831 (resized).jpg20201029_142831 (resized).jpg20201029_142833 (2) (resized).jpg20201029_142833 (2) (resized).jpg
#13 3 years ago
[quoted image][quoted image]
Here's mine.
1604012306375123895645813764452 (resized).jpg1604012306375123895645813764452 (resized).jpg
#14 3 years ago
Here's mine. [quoted image]
Thanks. Do you know how to check if a filter's bad? Maybe I should just assume mine is since I saw smoke coming out of the crimped wires lol
#15 3 years ago
I don't know. I would have to surf around. Knowing me, I would have had one comming before the smoke cleared.
#16 3 years ago
I would replace the EMI filter if it smoked.
The next thing is to check that the power plug is wired properly so that the "hot" wire is on the "hot" pin, etc. See the link posted by LTG above.
$ 18.95
$ 10.95
Third Coast Pinball
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
2,000
Franklin, VA
$ 12.00
Retro Electro Designs
This page was printed from https://pinside.com/pinball/forum/topic/lost-world-wiring-a-power-switch and we tried optimising it for printing. Some page elements may have been deliberately hidden.
