After many years (15+!), having an issue with the snagger toy in my Lost World. First it wasn't working at all, and drop taarget wasn't resetting. I found a loose wire/diode, reconnected, made sure drop switch worked. Also saw the flexible black plastic strip in the arm (covers the upper toothed belt and hinge area) was torn, so I removed that. (Still looking for a replacement!)
Now that it's back together, it almost works. It comes down fine. But, when going back up, it stutters a few times, and then starts to lift but the cycle ends before it is all the way up. Is this a belt alignment problem, or is the belt itself possibly defective? I have the manual but this toy is a PITA to work on, and I've not found a clear disassembly/adjustment guide. Does anyone have any suggestions?
Also, disabling the snagger toy in software isn't working, because the drop target isn't raising. The reset coil and switch for the drop are fine, and the reset and switch work fine in the test modes. Any suggestions? Thx!
