(Topic ID: 270468)
Lost service menu on Stargate
By dri
7 months ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 7 months ago by dri
#1 7 months ago
I had a weird incident with my Stargate tonight. I finished a mode and the ball locked in the right orbit. The game never ejected the ball and ball search was never triggered. The game appeared frozed while music was still playing. I did a power cycle and the machine kicked out the ball in the right orbit saucer.
Now, the game wouldn't start. It turns out the game is now asking for credits. The service menu that normally appears when you open the coin door isn't there. Switch diagnostics clearly shows that that my switch door switch is working.
I managed to coin-up and get the game started. It seems to play fine besides the Glidercraft mode is awarded a little bit here and there. I'm assuming the game have somehow dropped out of "tournament mode" and this is the expected behavior in coin operated mode?
Thankful for any hints on how to get this back on track.
#2 7 months ago
Sounds like the battery may have gone bad. It maybe a solder in style or in a socket quarter style battery.
#3 7 months ago
Probably a common wire n°666 (blue blue blue) link to coin door is unsold
#4 7 months ago
I've had that happen before but with the left orbit where the ball didn't eject or go into ball search, not sure what caused that but it hasn't happened since. Also had the issue where I couldn't enter tournament mode and it turned out to be a loose wire at the top left kicking target, re-soldered and it fixed the problem.
The Glidercraft mode is awarded automatically at the start of the third ball if you didn't activate it during the first two balls.
#5 7 months ago
Quoted from chad:
I wouldn't be surprised but shouldn't the HSTDs be wiped if that was the case?
#6 7 months ago
Quoted from Bonk:
Thank you kindly! The Glidercraft I suspected something like that but it doesn't start the mode in tournament mode. I'll do a survey around the playfield and see what I can find in terms of loose wires.
#7 7 months ago
Quoted from Benhurr:
Thank you! I'll have a look at this.
#8 7 months ago
Quoted from dri:
Yes they would be cleared. I read into it wrong. Hopefully it is just a wire broken.
#9 7 months ago
Quoted from Bonk:
How weird. Blue/green/green (655 in diagram above) had come loose on this exact kickback target (center) on mine as well. It doesn't help that I vaguely remembering soldering that wire back before, not having the service menu disappear. But that might've been the signal wire. There were like 5 strains in this wire so not surprised this is a common fault at all.
All good, thanks all!
$ 499.95
Pin Stadium Pinball Mods
$ 42.00
$ 15.45
KAHR.US Circuits
$ 249.00
$ 50.00
