(Topic ID: 236071)
Lost key/ universal keys
By Daditude
5 years ago
There are 59 posts in this topic. You are on page 1 of 2.
#1 5 years ago
I just got a Bally Lost World with no key to the backbox. It does have a key to the coindoor (which is not original), so they do not match. The backbox lock looks to be original. There is definitely no key inside the machine or anything. I cannot see a number on the lock.
Here is my question:
Are there universal keys to these? Does anyone know what type of key this would use?
I am not drilling or unscrewing it. I am simply trying to find a working key.
Any help is appreciated.
EDIT:
Answered:
There is no universal key. Possible other keys may fit, however (fort maxi keys).
Drill out or unscrew it...or shave the key mechanism down for any key to fit.
#2 5 years ago
Quoted from Daditude:
No, but more often than not, the locks can be picked. Spend an afternoon watching lock picking videos and try it on a new lock (older locks are harder since they are generally more gummed up. New locks have a lot better action and are easier to learn on).
If you can't pick it, drill it.
I've used both methods many times.
Once you have it open, but a new lock on. (As long as it's the same style lock, nobody cares if the lock is original or not, if that's what you're worried about).
#3 5 years ago
About 5 of my buddies and i went in on a bulk purchase of locks a couple years ago. We got them down to about $2/each and now all of our machines use the same key. Anytime a new machine enters the mix the lock is put aside and saved for when the machine leaves the group.
Coincidentally our locks matches the ones used in newer Stern backboxes so we can open any new stern and find our key.
We also take a lot of games to shows and events and carrying 1 key makes it easy to repair machines.
#4 5 years ago
I have access to the backbox and boards.
I am NOT going to drill or replace the lock. At all. I am strictly asking if I can find/use another key. If not, I wont worry about it...but I would prefer to have one.
#5 5 years ago
Kinda silly but I understand if you just wanna keep it the same and not spend the money on it. I kept my locks the same for about a year before I went in and bought new locks and changed out all my games. It’s easier now with matching keys
#6 5 years ago
You can take the lock to a lock smith and have a key made up its not cheap. They should make you the same key as the original one.
#7 5 years ago
The original lock is a Fort "MAXI" lock & key. The lock is 1-1/8" long.
#8 5 years ago
There is not a universal key for pinball backboxes like there are for jukeboxes and other coin operated devices. (The coin boxes on those have unique keys but many models shared the same keys to the guts, making things easier for service people)
If I understand correctly, the lock is unlocked so it is not preventing you access. If you do decide you want a key, as mentioned before, if you take the lock to a locksmith he can cut you a new key for it. I would add that it doesn’t have to be expensive, they are really simple locks. My local guy only charges about $10/$15 to do it if I leave it with him.
Since it doesn’t have to be Fort Knox quality, you can also disassemble the lock, slide another key in the exposed cylinder (maybe your coin door key?) and file down the proud brass bits flush with the cylinder until it rotated freely in the barrel with the key inserted. Now you have both locks keyed alike and it will be secure enough for home use.
#9 5 years ago
Jesus christ man just drill the goddamn thing!!!
Don;t worry you wont tarnish the legacy of...hm...Bally's lost world
#10 5 years ago
Uh, can I ask why?
A new lock is less than $4.
Does that mean you'll just leave it locked? You probably should open it to check on the battery situation, at the very least.
#11 5 years ago
Quoted from KenLayton:
Thank you!
I will look for one.
#12 5 years ago
Quoted from ForceFlow:
See post #4.
#13 5 years ago
Quoted from MrArt2u:
I have heard that there are a few "limited" keys that were used. Perhaps not "universal," but just a couple of options that might have been used. 2 people told me this: a guy with well over 100 pins and another gentleman that has run routes for years and owned countless pinballs (hundreds...and possibly thousands).
I have full access to the backbox and the boards. I am mostly trying to get a key to lock the backglass in place and just for the sake of completeness.
I may just shave the lock mechanism down to allow easy access with a different key or I am exploring the fort maxi keys, as mentioned by a poster above.
If anyone has further info on a key that might work (no more drilling suggestions...please), then please do share.
#14 5 years ago
Just unscrew the cam screw and lock nut and throw in a new lock.
#15 5 years ago
or take out the lock and pull out all the waffers of the lock so any key that fits will work , even a screw driver
#16 5 years ago
if you have access to a 1382 or 7500 key, those are the most common keys used recently and the closest thing to a universal key these days (only if the game has had new locks in the last 10-15 years or however long Steve Young has sold those 1382 locks)
I have several coffee cans full of old pinball keys sorted by type that have never let me down when I get a game without keys. (not applicable to you but for the sake of others - picking the lock and installing a new one is a lot faster than going through the can!)
I've worked on several hundreds of games myself and I haven't run across the "limited" key unless a bunch of games in a certain geographical area were all keyed alike by an operator at some point, so it is very possible.
#17 5 years ago
If you look at the lock, is there a number (or letters) on it? If so, you may be able to order that key.
#18 5 years ago
where do you get these locks that have the square on the end near that the cam attaches to. Had a hard time finding anything, most old games I buy are missing the key or drilled out.
#19 5 years ago
What the hell man... if you are already in the back box you have access to the back of the lock. Just remove it and install a new barrel with a key you do have.
There is no “originality “ or whatever here to save. Just put in the $4 lock.
#20 5 years ago
No... there are just common ones the people use. The number of key combinations they have is finite... but unless you know the barrels number you’re just brute force checking. Just replace the lock barrel and move on
#21 5 years ago
Being a locksmith almost my whole life these threads just crack me up.
#22 5 years ago
Quoted from Travish:
They crack me up too... especially when I am trying to do something simple like check a key into a lock (and for people checking this in the future), and people continually and without reading say drill it drill it drill it well after I have stated multiple times that I will not be drilling it.
#23 5 years ago
You don't need to drill it. Just unscrew it and put a new one in. You won't have to mess with going on a fruitless scavenger hunt trying to find the one random key that might match.
Out of curiosity, why do you want to keep the lock so badly? It's not necessary.
#24 5 years ago
I'm sorry. I cannot resist
Does this mean that you are a safe cracker?
#25 5 years ago
I am mostly trying to get a key to lock the backglass in place and just for the sake of completeness..
It is not that i want it so "badly." More like i stated above...it would be nice to have (not absolutely necessary).
It is also nice to have if i sell it down the road.
I was also asking just for future posterity of anyone checking these threads.
I looked tboroughly before asking in this forum, and there wasnt really anything that covered universal keys very well.
I like the idea of shaving it down so any key will fit it. A couple of posters mentioned possible options that i will explore as well.
#26 5 years ago
Yes but that can then let the tumbler drop down to far in the plug and the key will not go in. If you are trying to make a different key fit a cam lock and you do not have a keying kit, it's better to rearrange the tumblers (and possible leave one out) you do have to match your key instead of sticking the wrong key in and filing whatever's sticking up.
#27 5 years ago
You've totally peaked my curiosity.....Did you have a bad experience with a cordless drill at some point in your life?
I'm just curious as to why you're so against it? It resolves your problem, takes 10 seconds and will cost $4. I just have to know......
#28 5 years ago
There is zero additional value with a particular lock. It's probably been changed by the previous owners already, you're not preserving the factory original.
Replacing it is the best option.
#29 5 years ago
Looking for a random key to fit a peticular lock. Sounds like a life quest, something that you do just to say that you’ve done it.
Build a pin from scratch > just buying the game
Build a car > just buying a car
Finding THAT ONE KEY > just buying a lock
Sometimes the easiest solution is the wrong one
#30 5 years ago
Drill baby drill?
#31 5 years ago
Quoted from Spyderturbo007:
No. Im just sick of people saying to drill it. Thanks for being another person saying to drill it
#32 5 years ago
That's one of two standard ways to address a locked game with a missing key. That's why it had been suggested several times.
#33 5 years ago
Simple answer- No, you can not find/use a another key.
#34 5 years ago
I fully understand. I find it frustrating, however, when i have clearly stated that it will not be an option and people keep suggesting it...repeatedly...and not actually reading the thread...which has clearly now run its course...if not past.
#35 5 years ago
Personally, I think you're making more of a deal out of it than it has to be. Just replace the lock and be done with it.
There isn't a standard universal key. These locks can be keyed in thousands of different ways and there could be thousands of different keys. Without the key number, it will be nearly impossible to find a match. I keep a handful of recovered keys on-hand on the off-chance that they might open a lock when I'm picking up a game with missing key, but they never do. It's a lot easier and cheaper just to replace the lock, rather than going through the unnecessary effort and expense to have an actual locksmith come up with a replacement or re-key the lock.
Nobody cares if the lock is or isn't original. Operators almost always replaced them anyway to match their other games, so it's more likely than not that the lock is not the one that came from the factory.
As long as the lock is functional, that's all that really matters.
#36 5 years ago
Did you look inside your coin door and just inside the machine for the backbox key? Most the time they are hanging on the door or a hook just inside
#37 5 years ago
Oh I dont think so....I can tell by your replies there's lot of meat left on this bone.
#38 5 years ago
Did you try drilling it? Its easy...
I see why you incorperated "attitude" in your name...
#39 5 years ago
Quoted from cosmokramer:
Take the time to go back and look at this thread. There have been only 3 posts that have answered me appropriately, without asking or repeating something i have previously already stated...usually having stated it multiple times.
I think i have been quite patient.
#40 5 years ago
#41 5 years ago
don't drill it ! lol
#42 5 years ago
3-5 minutes of my life I will never get back. Goofiest thread ever
#43 5 years ago
Those are just enablers suggesting a complex solution for a simple problem.
Your inability to just do the most reasonable thing is baffling
#44 5 years ago
You could just drill it out.
Sorry, slow day at work.
#45 5 years ago
This needs a poll
1.drill it
2.waste your life
#47 5 years ago
Yes, you have been patient. But I think everyone is fascinated and trying to wrap their heads as to why you are fixated on this lock.
People restore pinball machines with repro new back glasses, new repro play fields, new posts, new rubbers, etc. And they will add new locks with nice shiny keys. And other than the lock working, I don't think anyone has ever given a hoot about a key lock other than "do you have the key, or do I need to bring my drill"?
You have your reasons---but we all are trying to understand.
And this is pinside; You are going to take some heat.
And people just love to see others twist in the wind
So, you need to grow some skin and get a sense of humor
#48 5 years ago
Also, you are aware that since it’s currently unlocked you can remove this lock without damaging anything? And that a replacement lock won’t differ in any way? They are all standard sizes, shapes, and mounting, and all look the same.
The only place you’ll even see a brand name for the lock is on the key (maybe) and possibly on the baggie it comes in.
Your local hardware store will even carry this type of lock and you could take the existing one with you to ensure you get one that has a bezel that looks the same.
I guess I am just really curious what is so important about that one specific lock with no keys, and what the downside is that you see in replacing it with a new one that comes with two keys? I think everybody is, actually..
#49 5 years ago
Take it out, take it to a locksmith, have a new key made, bring it back home and reinstall it.
#50 5 years ago
I am just curious too. Obviously you do not need to drill the lock if it is already open. I don’t understand why you don’t want to replace it. I think if you gave the reason as to why you didn’t want to replace it everyone would leave it alone. But hey what do I know lol. This is pinside so who knows
$ 69.00
Pinball Pimp
Retro Electro Designs
$ 69.00
Pinball Pimp
$ 10.95
$ 69.00
$ 18.95
$ 12.00
2,000
Franklin, VA
This page was printed from https://pinside.com/pinball/forum/topic/lost-key-universal-keys/page/1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
