(Topic ID: 306613)
Lord of the rings issue after ring is destroyed
By wbkwbk
2 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by MMGB
#1 2 years ago
Hi
This concerns #Lord of the Rings
After the ring is destroyed, the pin starts as expected to acitvate lamps/coils etc. After a while the error message: arise, and the software stalls where golum hangs from the last cliff. After a ball search, game goes back to normal.
I've added according Videos.
here: https://drive.google.com/drive/folders/1jPR3rt_KfNtGK-0Dm-nSsJ0-6i0ddxKj?usp=sharing
The Sequence is:
1_RingDestroyed.mp4,
after this the software hangs where golumn hangs off the cliff. But since the ring is destroyed the flippers are disabled and I have to wait until the ball search starts and then returns to normal play.
2_StallAfterFingIsDestroyedAndBallSearch.mp4
In the test menu coil #21 works perfectly well. So I have no idea what could be wrong. Any hints are very appreciated.
Thank you
#Lord of the Rings
#2 2 years ago
There is a microswitch on the wireform tube in the back there - make sure that is adjusted properly so that the game knows everytime the ball passes through behind the ring.
Other than that I have nothing.
#3 2 years ago
Thank you I'll check that. Although I expect it to work, as the Ring destroyed sequence 'everything on ghe playfield is shaking and moving' is initiated only after a while of everything is shaking this error message appears. I would expect if the switch is not working the destroyed ring sequence of everything shaking would not start.
But I will check anyway
#4 2 years ago
Check switches 17, 18, and 19 to ensure they aren’t stuck closed or sticking closed for a while after a ball rolls over them. Maybe the machines thinks a ball is still on one of those switches and that coil 21 isn’t working to allow the ball to move. Just a guess, but seems logical.
#5 2 years ago
Quoted from MMGB:
Thank you, yes, I will do that the switches: Sword Lock High, Sword, Lock Mid, Sword, Lock Low.
In the static tests they work fine, but it's for sure another story during ring destroyed mode, when everything is shaking. So I am thinking of probably replacing them all.
#6 2 years ago
Thank you all for your support
The issue is solved. Switch 24 (right ramp made) one cable was no longer soldered.
#7 2 years ago
Glad you figured it out!
Lenticular Designs
$ 200.00
Professor Pinball
$ 259.99
$ 41.00
$ 99.99
RamMods
$ 12.99
Mitchell Lighting
$ 49.99
$ 5.00
Pinball Fuzz
$ 12.00
$ 50.00
Duke Pinball
10,000 (Firm)
Denver, CO
PinWorlds
$ 130.00
Dijohn
10,000
Narragansett, RI
9,500
Leawood, KS
RamMods
RGP Models
€ 7.50
$ 1.00
Pinball Alley
9,500
Birdsboro, PA
$ 19.95
Mitchell Lighting
