The lower left spotlight on my met pro keeps slowly rotating to the left. The lower right on never seems to move at all. I dont remember air balls hitting the spot. The light itself is screwed tight on the top of the post, But the entire post is rotating. Ive attempted to tighten it while keeping the spot pointed in the correct area, but it keeps getting loose...
I see similar designs on other stern tables. Is this common, or Met specific? Maybe its just my pin?
Any suggestions on how to get it tight so it wont spin. It would be better if stern would use a bracket with two connection points at the base.. But id be open to suggestions on ways to keep it from spinning as is.
Thanks in advance.
