hello
how do you fix loose flippers. i don't mean at the crank arm. the flipper holds its lock.... it just is loose in side to side movement.
thanks,
mike
hello
thanks,
mike
Did you check to make sure all the components are tight including the bushings and the main flipper plate? I assume that's what you mean when you say loose side to side? Or do you mean the flipper bat is actually loose on its post? If that's the case, you need new flipper bats.
it probably is the bushing.
i avoid changing them because i have broken a couple of screws over the years trying to get them off.
You really should replace the bushing whenever doing a flipper rebuild (I know they're not in the kits, but they should be). Red loctite was probably used on the previous rebuilds hence why the screws broke.
Quoted from terryb:Red loctite was probably used on the previous rebuilds hence why the screws broke
Yup. Always use blue loctite.
Don't know about those guys, but this guy has been reassembling pins for 30 years, I've never applied a drop of the stuff. And nothing has fallen off yet.
Quoted from JoeGrenuk:Don't know about those guys, but this guy has been reassembling pins for 30 years, I've never applied a drop of the stuff. And nothing has fallen off yet.
True that.
I've used blue on a few things that take excessive vibration or trouble areas but I agree, it is generally not needed but certainly doesn't hurt.
I've never needed it on a pinball machine either.
This page was printed from https://pinside.com/pinball/forum/topic/loose-flippers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
