I have a F-14 Tomcat pinball machine and the T in the top left is not working. If shows closed in the switch diagnostic but the switch itself seems to be working correctly when tested with a meter. I was thinking of replacing the switch (unless there is something else I should be checking since the switch itself doesn't seem to be closed). I can't find the replacement switch online which is part number SW-1A-162-2. The red target it is connected to has the material behind it gone - is that something I should replace? (The other targets have a bit of 'foam' behind them and this target does not). Hope that makes sense and thanks!!
Piratewoo
