I've got a Phantom that sat in storage for a few years and now it's got a couple of problems that I'm hoping someone here can help with. The problems I'm working on are:
- There's a fuse on the flipper board that blows anytime I activate the left flipper.
- After the first ball drains a new ball is not ejected.
For the flipper problem I've looked for mechanical problems and don't see any, but I'm not sure how to test the individual components on the flipper board.
I've tried a number of things for the ball eject problem. Here's what I know:
- In the Active Switch test the only switches that are listed are the Organ Closed (which makes sense), Left VUK 1, and the 3 ball trough switches.
- The edge switch test shows correct behavior for the shooter lane switch, the ball trough switches, and the outhole switch
- When the first ball drains it correctly triggers the solenoid to move the ball to the ball trough
I've reflowed the solder on all of the ball trough switch connections (although I'm not certain I got them all full melted). I haven't seen anything else that fails. All of the other diagnostics look ok to me.
Have any of you seen anything like these? Any suggestions?
Thanks,
Don
