Looking for some help on Williams Stellar Wars
(Topic ID: 207130)
By HD_Fatboy
1 year ago
  • 142 posts
  • 8 Pinsiders participating
  • Latest reply 7 months ago by trk12fire
There have been 9 images uploaded to this topic. (View topic image gallery).
There are 142 posts in this topic. You are on page 1 of 3.
#1 1 year ago
All my current games are EM. So brand new to SS so be gentle on me.
I picked up a Stellar Wars pin last week, so I am new to SS. It had the piece in the cabinet where the back box attaches broke. I made a new piece, and when I did I took the playfield out of the pin and put on saw horses to disassemble for cleaning and waxing, and to go over to look for anything wrong.
I put everything back together, and when I switched on the pin all the playfield lights were flashing all around and such. I assume this is normal some type of light test.
I pressed the start button and one pop bumper stuck on ( cant figure this out, these were all dissembled for cleaning and appeared to be free on movement)
Any way shut down pin right away so I wouldn't burn up coil. Took apart pop and reassembled to make sure it is free. Now when I press start, nothing happens, nothing on playfield activates and scores, flippers don't work. Press start nothing happens, I can not get into diagnostics, and or settings.
There is a yellow wire with a diode or resistor hanging from coin door it looks like its from on coin switch. there is two green with brown stripe wires tied together not connected that looks like it went to the score reset switch, this switch is broke where it looks like these wires may have been. Wires are still soldered to the small tab. I can not find these switches or these colored wires on my schematic. but it looks like that's where these wires were at one time.
Player one has points, all others are at zero. I have the back glass off so the other two displays have 03 00. don't know if this helps at all.
Sorry for the long post, but I am looking for a starting point on how to trouble shoot the issues.
Thanks in Advance!
#2 1 year ago
Sounds like a short. Maybe something got together when you had the playfield out. Hopefully just blew a fuse. Look it over really good and see .
#3 1 year ago
Forgot to mention, All fuses checked out OK.
#4 1 year ago
Those wires with a diode for menue can definitely cause a short. A fuse should have blown. I would fix that and then start looking at if you are getting power. If anything blew on the boards after that.
#5 1 year ago
Not sure if you did or not, but you can get a false read if you don't take fuses out to check.
#6 1 year ago
Thanks Buzz, I will check things out tonight after work and post back.
#7 1 year ago
Check your solenoid fuse. Also, it sounds like you are booting up into Audit mode. There are a few causes for this, most likely culprit is bad and/or dead batteries. Open your coin door and turn the game on, then off and back on. It should boot up. Good luck!
#8 1 year ago
Quoted from Brypten:
Thanks, I will check this out also!
#9 1 year ago
Which pop is sticking on?
For the pops, coil #7 is MPU controlled, coils 17,19,20, and 21 are special solenoids.
If it is a special solenoid coil, they use a separate direct activation switch - check the activation switch for short or contacts touching. A permanently stuck on switch will cause that pop to lock on. Switch test won't help here, as the switch test will onlyt detect the scoring switches (these are different switches that do not control the pops coil, they just register the points)
Once the possibility of a stuck switch is ruled out, then proceed to test the coils drive transistor/circuit.
#10 1 year ago
Quoted from wayout440:
Top Left hand POP I do not know the number. Being I have EM's, I checked the contacts under the playfield.
As I said, I am very new to SS machines.
How do you test the coils drive transistor/circuit?
#11 1 year ago
Quoted from HD_Fatboy:
So just to be certain: You checked the spoon switch with a DMM for high resistance when the switch is open?
Top left is solenoid #19 according to the manual. Drive transistor Q6.
To test: Game power off. Remove connector 2J12 (prevents skewed reading from playfield coil) Set DMM to diode position. Put the black lead of your DMM on the center lead or on the metal tab of the transistor. Put the red lead of your DMM on each of the two outside legs of the transistor. You should get a reading of .4 to .6 volts. Any other value, and the transistor is bad and will need to be replaced.
#12 1 year ago
Like I said, first SS game and I have tons too learn!!!! I only checked the opening and closing of the switch contacts. I will be getting the DMM out after work. Thanks again everyone for your help, I will post back how O make out!
#13 1 year ago
I replaced the batteries, and now I can get into diagnostics, lots of failed solenoid and switch tests failed.
#14 1 year ago
The main thing happening that makes trouble shooting more difficult is,,,,,The right top pop bumper coil is being pulled in and scoring and not releasing. The switches under the pop bumper are not made when this happens.
#15 1 year ago
If you need pictures of anything Stellar Wars related let me know.
#16 1 year ago
Quoted from mswhat:
Thanks I appreciate that
#17 1 year ago
Now that you can get into diagnostics, take care of the switch problems first. Mark all the switches that are failing on the switch matrix diagram so you can see if there are any common relationships.
#18 1 year ago
Hi wayout, thanks again for the help, problem is right now I can not do switches first because top right pop bumper is constantly firing. It pulses as soon as you get into the switch test mode, or when you try to start a game. Should I take one lead off the coil for now and do the switch test?
Also three of the drop targets solenoids are not working. All the coils are brand new, the person I purchased the pin from just had them installed.
#19 1 year ago
Unplug the connection that controls that coil or coils to be correct from the mpu. That will isolate so you can work on switches and then get back to that problem which is probably connected to the switch issue.
#20 1 year ago
Thanks Buzz!
#21 1 year ago
You can look at your schematic or by the wire color
#22 1 year ago
I mentioned removing connector 2J12 for those solenoid earlier in the thread. That will stop it from locking on if there is an MPU problem.
#23 1 year ago
Wayout440 is correct you need to check those transistors after your done playing with your switches. If one is bad the coil will lock up again. Very good advice mentioned above.
#24 1 year ago
Quoted from Buzz:
Thanks Wayout, What is the testing procedure for new coils that are not firing?
#25 1 year ago
Post #11. Explains how to test for bad transistors. Then you can go to the next step. Important to focus on one thing at a time.
#26 1 year ago
Did you get the switch problems resolved and coil transistors tested? Once that's done, fix the locking on problem.
Then, the next step would be to tackle non working coils.
#27 1 year ago
Hi wayout, I am at work now, be home around 6:00pm. I will post my results when I test further. Thanks for checking!
#28 1 year ago
I have some failed switches, they are making contact, I really am at a lost now on how to fix some of these things. top right bumper is fine until the coil is fired then it stays energized.
#29 1 year ago
It's going to be overwhelming until you start to narrow things down. You have to pick one thing. Go to YouTube and watch the pinball ninja video on LW3, I think it's the only video. Also watch the pinball repair of T2 that jack danger made I think it comes up if you type pinball repair. Both had multiple issues and you can see a good way of attacking this stuff. Isolation is a key and one thing at a time. I think it will help you so all this doesn't sound like Chinese.
#30 1 year ago
Here is something I noticed, The items with the white and yellow colored coils are the items not working correctly.
The items with the orange colored coils are working correctly.
The previous owner just put on the white and yellow coils.
#31 1 year ago
My pictures did not show up I will try again
#32 1 year ago
Could be a faulty transistor, wire,fuse,diode, ?? Watch those videos they will help you I guarantee it.
#33 1 year ago
#34 1 year ago
Old coils and new coils not an issue. Check the serial numbers if you want to make sure they are correct. Then find out why they are not working.
#35 1 year ago
Does it matter if the numbers don't match exactly? I tried to search and find the videos but no luck.
#36 1 year ago
#37 1 year ago
#38 1 year ago
#39 1 year ago
Stop, please.
Slow down.
Coil part numbers are listed in the manual in the solenoid chart.
There are several different coils in this game...so the part numbers so matter.
Did this game ever work in your possesion?
#40 1 year ago
Stop, please.
Slow down.
Hi Wayout, The game never fully worked in my possession. The things that did not work are the items with the yellow white coils in my pics,
#41 1 year ago
I watched the videos, but sorry They did not help me much, I think because my game is nothing like them.????????
#42 1 year ago
So did you check to see if coils are correct for your pin? Did you check to see if you have voltage at coils? I thought the videos would help as a reference on troubleshooting.
#43 1 year ago
Quoted from Buzz:
The videos were mostly changing bad molex plugs. I don't have material to see what are the correct coils...still looking...but if you look at my pics, the coils that work are SG=23 850 DC the coils that don't seem to work are SA=23-850 I do not know if the letter makes a difference or not.
#44 1 year ago
Those are the proper coils. Now time to test for power to them and let me know if you have power at the coil.
#45 1 year ago
Quoted from Buzz:
Sorry I am dumb, but how should I test for power at the coils?
#46 1 year ago
Digital multi meter
#47 1 year ago
Wait stop!!! Do you have a meter???
#48 1 year ago
This will show you a DMM and how it's used.
#49 1 year ago
I guess the SS games are harder than I thought, EM.s seem easier
#50 1 year ago
Ok, I read in a thread in here that you could force the coils to fire by putting a jumper from one of the coil lugs to ground. I did this test, and the coils fired. do I need to figure out where the wiring goes?
650 (OBO)
Greenville, PA
$ 18.00
Yorktown Parts and Equip
$ 104.00
$ 42.00
The MOD Couple
$ 149.00
$ 5,799.00
Gulf Coast Pinball, LLC
$ 76.95
$ 89.99
Tim's Pinball Mods
$ 125.00
Sparky Pinball
$ 69.95
Hookedonpinball.com
$ 29.99
