Hi there,
Can you help me with a LOTR LE manual. I want to check which fuses are being used (for example on the flippers). At the end it's great to have a manual lying around.
Thanks for your attention!
Peter
Yeah, sorry you are right about that. I meant the diodes are different. At the board and next to the flipper units.
Anyway, there are some differences, better to have the LE version documentation if it excisted.
https://www.ipdb.org/files/4858/Stern_2003_The_Lord_of_the_Rings_English_Manual_complete.pdf
don't think there is a specific LE manual. if you look at the differences I assume electronic wise they are the same (minus the option of the shaker)
Here are the factory changes that differentiate the LE version from the original version:
• The backglass is real glass (not a translite) with a mirrored gold effect.
• Extra clearcoats on playfield.
• 'Armies of Middle Earth' plastic figures were not used. Therefore, no mounting holes exist in the playfield plastics for them.
• Playfield is signed by Gary Stern and George Gomez.
• "Gold" trim. The lockdown bar, legs, hinges, and side rails are plated and polished. Gold trim around the backbox.
• Game has the option to add a Shaker Motor.
• Leg bolts and hinge bolts are brass plated.
• The speaker panel has a "500 Game Limited Edition" plate and gold painted grills.
• Certificate of Authenticity signed by Gary Stern.
Biggest change in technical aspect is that the LotR-LE has no longer a whitestar boardset but has mixed SAM and WhiteStar boards.
I was always curious if they used he bidirectional board for Balrog on the LE, didn't see it under the playfield, but also couldn't find documentation haha
Thanks for the feedback!
I thought reading the manual extensively would help me understand the machine better.
About the boardset. Since I blew my board repair trying to solve my blowing flipper fuse, board diode, transistor circular problem I ended up buying a new board for this LE. I learned this week about the diode also needed to be replaced.
The board was crazy expensive (+$500,- from
germany) but Im happy that it’s coming to enjoy the machine again after too long.
I need to practice my board soldering. There is also some solder (flux?) on the green lines on the board and I think that messed it up as well. Im not sure. Not easy to fix this board issue messing the board up being a solder noob
Thanks again!
Peter
Thanks dcfan!
Do you mind scanning more of your manual? So I can print and document it and maybe get it on ipdb?
http://www.firepower.2ya.com/14-lotr.html
Think that all what you’re looking for is here.
Quoted from KLR2014:http://www.firepower.2ya.com/14-lotr.html
The links are dead.
Thanks for the reply. The missing pages link does work. The actual LE manual link is broken unfortunately.
Quoted from PinPeet:Thanks for the reply. The missing pages link does work. The actual LE manual link is broken unfortunately.
The missing pages link is working for me. It shows the pages that are missing from the LE manual. I am guessing when they put the LE manual together they forgot those pages (human error). The LE manual appears to be mainly a hand edit of the original manual with a few complete pages like the fuses swapped out since that was totally different.
I don't have the time to hand scan every page of the manual, especially since the manual is bound and I don't want to take it apart to scan it through auto-feed. If I have a chance I will take a look and see if I can scan the specific pages that have edits for LE.
Have you tried contacting Stern to see if they can sell you an LE manual or post it on their site?
This page was printed from https://pinside.com/pinball/forum/topic/looking-for-lotr-le-manual- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
