Fix up a Gottlieb Super Orbit but I am more of a Bally person so my knowledge with Gottlieb is limited. Doesn't help that there is no manual with the machine either. In looking at the attached picture you can see someone hacked the IC Socket. This socket is at the top of the CPU board and just below the Reset Board. If I am correct in my thinking this IC Socket is not used???
When I play the game everything scores as is should but the displays show garbage. If I turn the game off and back on the Displays will reflect all zeros, with the exception of players 1 and 3 the last digit reflects nothing. So it appears that the game is not keeping its memory and there is also an issue with the information being sent to the displays. I have checked the connectors and pins to the displays to no avail.
Appreciate any insight into the above issues! Thanks meSz
