I'm going to start the restoration on my TAF playfield soon. I need a high res scan to use to create decals for the spots worn down to wood. Thanks in advance!
Which areas do you need? I have a HP 4600 scanner so I can scan those for you (if they are not also worn on my spare playfield).
I appreciate it. There's a number of spots - The right power arrow and arrow next to that, the right inlane, ring around the bookcase, the chair kickout, Festers head.
Thanks.
Will this help?
https://dl.dropboxusercontent.com/u/93602694/Untitled.jpg
It's a playfield scan that I used when helping to update the Visual Pinball table. It's a rather large file (39 megs) but below is a small (low res) version.
I'll do that. It's going to take a bit to learn the graphics programs I think. I attempted to load the file into photoshop last night and mess around with it and I think I need a new computer because it slowed the machine down to a crawl.
Chop the image up into smaller chunks that cover the areas you want to work on.
For instance, if you need fester just use the Marquee tool. Make a box around him and then layer via copy. Then take that layer and duplicate it to a new window. Now the file size will be MUCH smaller and should work on your computer. (this is for photoshop).
Quoted from 85vett:Chop the image up into smaller chunks that cover the areas you want to work on.
So I created a new photoshop file and sized it at whatever the PF size is, I believe 20.5" x 46". I then dragged the file I downloaded from you onto the background layer. This pretty much locked up my computer while it was processing so I had to walk away. If I use the marquee tool and just crop the section I want like festers head, will it keep the size so when I print the decal it will be sized correctly? I'm just trying to focus on sizing at the moment and then once I get that down I want to move to vectoring and color adjustment etc.
Yes, it will keep the sizing when you copy the portion you need. If you use the duplicate layer into a new window it will keep the sizing as well.
Here you go - https://dl.dropboxusercontent.com/u/93602694/The%20Addams%20Family.jpg
I have a free drop box account so I have to clean it out sometimes due to space. If it's removed again and someone needs it please PM me and I'll load it up again.
This page was printed from https://pinside.com/pinball/forum/topic/looking-for-high-res-taf-pf-scan and we tried optimising it for printing. Some page elements may have been deliberately hidden.
