All the "chrome" flipper buttons I've seen wear down to the base plastic color after a moderate amount of play. YMMV
Quoted from yancy:All the "chrome" flipper buttons I've seen wear down to the base plastic color after a moderate amount of play. YMMV
Put several coats of clear over them and they will last.
But then will the moving part stick in the housing? It's a pretty snug fit just from the mold itself.
Quoted from yancy:But then will the moving part stick in the housing? It's a pretty snug fit just from the mold itself.
Light sanding of the plastic with high grit followed by several light coats on the top of the push button itself. Leaving the shaft and button housing alone. If the clear is obvious then its on too thick. Think of the sub assemblies people clear on restorations (coin doors/mechanical assemblies/brackets/housings). All of which might start off rusty or tarnished, then put through a tumbler or mechanically sanded only to remove the top coat (zinc/nickel/chrome) and have to be cleared. Many of which are tight integral moving parts.
This page was printed from https://pinside.com/pinball/forum/topic/looking-for-chrome-flipper-buttons and we tried optimising it for printing. Some page elements may have been deliberately hidden.
