Art,
This looks like a great starter kit with enough selection to do a complete LED job on just about any pin!! I suggest that you select a 25 pack of frosted warm white in wedge 555 base, a 25 pack of frosted natural white in wedge 555 base, a 25 pack of frosted warm white in bayonet 44/47 base, and a 25 pack of frosted natural white in bayonet 44/47 base. Most pins use a combination of both different type of bases and with both frosted warm and natural white you will be able to best color match for any situation. And of course Art is also including a good selection of colored LEDs that you can use to highlight specific inserts and highlight specific GI areas.
What a great deal!!
From my experience here is what I have come up with regarding some basic ground rules in LED choice and use, and with this starter kit you will be able to accomplish a lot of what I recommend below:
1. I prefer the frosted 1SMD 5050 for almost everything as it gives a nice bright smooth dispersed light for inserts, under plastics for GI, and behind the back glass.
2. For back glass and under playfield plastics use warm white LEDs behind warm colors such as yellow, orange, and red, and use cool/natural white behind cool colors such as blue, green, and purple. You can use a colored LED for a "special effect" in some areas if desired. Again the frosted 1SMD 5050 works great here.
3. For inserts you can also use the frosted 1SMD 5050 but match the color of the LED to the color of the insert. The only exception is for yellow inserts. Do not use a yellow LED under a yellow insert. Instead use a warm white LED. Yellow LEDs are not bright enough and are only useful behind white inserts.
4. Use different color LEDs under white inserts to give you a more colorful playfield if that is the effect you want.
5. Use colored LEDs under playfield plastics to create a more modern colorful look if that is the effect you want.
6. Use specialty LEDs such as color changers and flex heads for those areas that may need them. Flex heads are good for where you have a sideways mounted bulb under an insert but I have found that the regular frosted 1SMD 5050 LEDs do put out enough sideways light to work just fine also.
7. Every game is different so feel free to experiment with different color and type combinations. It is always a good idea to purchase a few extras so that you can experiment.
8. The most important rule sometimes is to not follow any rules. If you think it might work give it a try. If you think it won't work give it a try anyways! You will never know what works until you try. It's only a bulb and it can easily be changed out if it doesn't work for you.
Pick up Art's Great Starter Kit and follow the guidelines above and I promise you a great looking pin!!
Thanks again Art for giving us all the best product, service, and price available for all our LED needs!
