(Topic ID: 283742)
Looking for advice on how to repair this WPC Power Driver board
By PittPin
  • 15 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by Pin_Guy
#1 3 years ago
On my Addams Family I have the GI-1 string out. I checked continuity of the brown and the white/brown wires to the lamp sockets and that checked out. I checked the voltage at J120-1 and 7 and got nothing. There was continuity from J115-8 to Q18 pin 1. Fuse F110 was tested out of the holder and was good.
So then I checked continuity from J115-3 to fuse F110 and found NO continuity (I checked from header pin 3 to fuse and then removed the board and checked from the solder joint to the fuse). Visually the board looks fine. Could the trace have just gone bad somehow?
I attached the pinwiki diagram of the circuit I am checking and a photo of the bottom of the board. The photo and drawing are not in the same orientation. I am looking for some advice as to how you would fix this.
IMG_2921 (resized).JPGIMG_2921 (resized).JPGTAF- Brown GI buzz (resized).jpgTAF- Brown GI buzz (resized).jpg
#2 3 years ago
Quoted from PittPin:
The through hole is probably damaged or missing at J115-3.
You can put a wire from J115-3 to F110 or repair/stitch the through hole.
trace on topside = brown line in picture
#3 3 years ago
Hmm sounds like the through holes have split and are not making contact now. The easiest way is to run a jumper. The hard way is to pull the header and slip a wire in the hole to solder to the trace to the other side of the through hole and then reinsert the new header and resolder it all.
#4 3 years ago
Can the through hole be repaired/replaced, or is the jumper wire an acceptable fix?
#5 3 years ago
Jumpers are fine. Stitch the hole if/when the header needs to be replaced.
#6 3 years ago
I give the jumper a shot. Thanks to both of you.
#7 3 years ago
Yes to both questions; just make sure to use an appropriate sized jumper as this is a high current connection (relatively speaking).
I am literally the only person I know of that still performs actual through hole/trace repairs as this requires both advances skills and specialized parts and equipment which doesn't make this type of repair cost effective. The only advantage offered by a true through hole board repair is that when performed properly it's guaranteed to last for the life of the board.
This is what a true through hole repair looks like prior to tinning the new vias:
#8 3 years ago
Jumper installed as shown above and all the lights are back on.
#9 3 years ago
Quoted from Pin_Guy:
Used to know a guy who did the true repair but he has long since retired. The repair jobs were fantastic and still holding up well over 30 years now!!!
#10 3 years ago
What would be an appropriately sized (gauge) jumper?
Solid wire? (I picture this being the better option from an ease perspective and less risk with errant strands)
Stranded?
I need to make a similar change jumpering the (to be removed) 8 large 6A2 diodes for GI.
#11 3 years ago
16 or 18 gauge is fine. Cheers
#12 3 years ago
Quoted from Hawk007:
Solid or strands? Thanks!
#13 3 years ago
I know pinsider Grumpy still does this too. I want do this on my repairs but the kit is really spendy if you only make a couple repairs here and there.
What parts/kit do you use on your repairs? If you don't mind me asking, that is.
#14 3 years ago
Quoted from Tomass:
I use a combination of Pace Cir-Kit trace repair kits and solid copper eyelets from a company that closed it's doors a few decades ago.
#15 3 years ago
Quoted from bikefreak:
If I was using a jumper, I would use 18 gage solid wire.
$ 29.00
Pinball Photos LLC
$ 24.00
Various Novelties
Pinball Photos LLC
20,000 (OBO)
Oakdale, CA
$ 159.00
€ 47.00
PPmods
$ 399.00
26,000 (OBO)
Auckland, NZ
$ 109.99
$ 145.00
Twisted Tokens
Comet Pinball
14,500
Pleasant Hill, MO
$ 84.99
GMods
$ 1,059.00
$ 180.00
$ 28.99
Lee's Parts
$ 53.99
$ 119.00
Loop Combo Pinball
$ 95.00
Twisted Tokens
Metal-Mods
Uberlaser
$ 29.99
NO GOUGE PINBALL™
$ 24.00
Various Novelties
Pinball Photos LLC
$ 9.95
11,000 (OBO)
Hanford, CA
$ 24.25
The MOD Couple
$ 31.99
Lee's Parts
This page was printed from https://pinside.com/pinball/forum/topic/looking-for-advice-on-how-to-repair-this-wpc-power-driver-board and we tried optimising it for printing. Some page elements may have been deliberately hidden.
