Here's what I know. It's on the board, and not the wiring to / on the playfield. Centaur orbs special light. I have checked the SCR and it was fine, but I replaced it anyway, in this case Q5. I have tested the resistance of R5, and it is in line with the other resistors around it. I have checked the traces from J2 pin 16 to the leg of the SCR, and it's both good and not shorting to anything else. I have tested the trace from the resistor to pin 13 of the U1 chip, and it's good.
Is my only option that U1 is bad? And no other lights are locked on or off. Thoughts? Thank you
AS-2518-23
