Quoted from undrdog:The lock relay is powered-- when I manually close it, the magnet holds it closed.
But why doesn't it pull itself closed?
Looks like it could use a good cleaning. 300-400# sandpaper and rubbing alcohol.
How strong is the pull when you close it manually?
Quoted from currieddog:Looks like it could use a good cleaning. 300-400# sandpaper and rubbing alcohol.
Firm, but it can be pulled apart without too much effort.
Quoted from undrdog:why doesn't it pull itself closed?
This switch on the Start relay should pull the Lock relay (and the Outhole solenoid) closed.
pasted_image (resized).pngWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/lock-relay-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
