New! Dark mode!
(Topic ID: 162764)
Little help... I'm stumped.
By donnPin
  • 11 posts
  • 7 Pinsiders participating
  • Latest reply 4 years ago by Keetur
#1 4 years ago
Recently while playing my Mata Hari (ss) pin, I had an issue with "chattering" on the right flipper (some call it "machine gunning" or "stuttering"). Checked a few things and decided to buy a new coil. After replacing the coil, the chattering is corrected however the flipper is not as strong as before. I have cleaned all the components of the coil and reset the coil itself. Any ideas? Again, its functioning but not as strong.
#2 4 years ago
Could it be a bad coil?
#3 4 years ago
Check the gap on your end of stroke switch.
#4 4 years ago
Quoted from donnPin:
Probably not.
Make sure the plunger slides easily into the coil sleeve without binding.
Make sure the EOS switch is filed, cleaned, and adjusted correctly.
Not much else to it.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
#5 4 years ago
Thanks for the response(s). Any quick notes on the "adjustment" of a EOS switch? I compare to the other side and it appears to be the same. Is there a "rule of thumb"?
#6 4 years ago
Check the resistance across the closed contacts of eos switch and cabinet flipper switch .Clean properly adjusted switches should read .03 ohms
#7 4 years ago
Once you've ruled out everything else, then it could be. Sometimes there can be a break in the wire of the coil.
#8 4 years ago
Just got finished adjusting the EOS switch and cleaned very well. Problem solved. Thanks for all the responses!!! Headed back to the Mata Hari.
#9 4 years ago
Check out Vid's guide. EOS is a likely culprit.
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers#post-284680
#10 4 years ago
Oops - spent too long finding that link - well done!
#11 4 years ago
Depending on the condition, consider rebuilding both flippers. Very easy to do, all the houses have "standard" parts, and the return on your time is instantaneous, and very gratifying.
It will be like a brand new machine again.....
Third Coast Pinball
$ 159.00
$ 50.00
