Bumper fixed!.. thanks to those who helped..now all my topside lights are out…under playfield is good. Sound ,,everything else good ugggh
I checked the lamp fuse it’s good all the backboard lights work everything under the play field the sound.. I wish it was that simple
Quoted from Mikenindy:now all my topside lights are out…under playfield is good.
What do you mean by topside lights? Are you talking about the General Illuminating (GI) lights?
Also, is this for Road Kings?
I was able to get the lights working again sound a wire that look like it had been pinched at some point… Thanks anyway
So my advice about not buying coil’s off of eBay was correct… The two flipper coils lasted about 10 minutes apiece before they overheated… Where is the best place to get a replacement Williams flipper coil?
Quoted from Mikenindy:The two flipper coils lasted about 10 minutes apiece before they overheated…
Are your EOS switches wired right and opening up quick enough ? Vid's guide might help.
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers
I’m in Indianapolis Turns out coils over heated because contacts fused shut got a rebuild kit on the way for both sides
Quoted from Mikenindy:contacts fused shut
If they are high power contacts, you can file them, they are tungsten. If low power, don't bother, they'll burn quick again.
This page was printed from https://pinside.com/pinball/forum/topic/lights-out- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
