Lights Not Working
(Topic ID: 238469)
Lights Not Working
By PokerJake
8 days ago
  • 15 posts
  • 4 Pinsiders participating
  • Latest reply 3 days ago by PokerJake
#1 8 days ago
I have three light sockets not working. They are the number 1, 2 and 5 in the middle of the playfield. I've tried leds and incandescents. Anyway I can test the socket? I have a multimeter but no idea how to use it. Attached is a photo of the socket
#2 8 days ago
Look at some utube videos to learn how to use a multimeter. Once you’ve done that, read the voltage at the bottom of the socket - one lead on the ear and the other on the body. You should read around 7 volts ac.
If you have the voltage on the bottom, you should have it in the socket. One probe on the spring in the center, the other on the side. Don’t let the leads touch each other. If they do, expect a blown fuse.
If you have voltage inside the socket, the bulb should light.
#3 8 days ago
I must not be taking the readings from the correct spot. Insert 1 measured 4v, insert 2 measured 7v insert 5 measured 5v. I tried multiple bulbs in insert 2 and still no light.
#4 8 days ago
And test the diode too if it's bad.I happen sometime.
#5 8 days ago
Diodes tested good
#7 8 days ago
Thanks, it has to be a bad socket. I'm not getting any switch issues.
#8 8 days ago
Here is the schematic, looks like they are all in a line after number 4.
#9 8 days ago
I would say Strobe 8 (Violet black black) wire is broken between "Snow boarding" and "Mogul", assuming L84 is not used or not working.
#10 8 days ago
Quoted from Mageek:
I checked for continuity between the socket and plug along the v/b/b wire and it checked out.
#11 8 days ago
The wire goes to L84 after #2, does it work?
#12 8 days ago
Not sure what L84 is or where it is
#14 4 days ago
Can you share what the issue was ?
#15 3 days ago
A drop of solder on the first socket and braid wire connecting to the other 3 sockets. Apparently there wasn't a good connection.
Gweem's Mods
2,000 (OBO)
Columbus, OH
$ 249.00
$ 126.95
Great American Pinball
$ 19.95
$ 750.00
$ 76.95
€ 8.10
Buthamburg
€ 3.95
Multigame
€ 222.00
Buthamburg
$ 48.00
$ 0.00
Operation Pinball
$ 10.50
The MOD Couple
$ 79.95
