(Topic ID: 231745)
Light problems with FunHouse
By gpmike
4 months ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 4 months ago by zacaj
#1 4 months ago
All at once, it seems, the following lights do not light: 1) Half the GI lights on the backbox, 2) All of column 2, and 3) All of row 2. Is this just bad luck, or something deeper? I have not had a chance to troubleshoot anything except the GI lights, except that it's not the fuses or anything in the wiring past the power board.
#2 4 months ago
Try reseating the ribbon cable between MPU and driver.
#3 4 months ago
This will sound crazy, but check it out ... I had a funhouse that was missing the plastic coating on the lockdown bar lever. When the coin door was closed, it shorted to the bulb behind the coin slot. Mine blew a fuse. Had to wrap the lever in electrical tape and solved the problem
#4 4 months ago
zacaj, you just saved me a TON of work, because I never would have thought of that. It did solve the problem. THANKS!
#5 4 months ago
Quoted from gpmike:
I only knew that because three hours before you posted, I went to play my Funhouse and noticed about 15 lights were out, plus one string of GI in the backbox, and then I spent half an hour wiggling connectors before finding that ribbon cable.
I replaced mine with a new one. If it has problems once it'll probably have them again, and cables are cheap
$ 129.00
LED OCD
Yorktown Parts and Equip
$ 44.99
Lee's Parts
Trade
Machine - For Trade
Fort Wayne, IN
Gweem's Mods
$ 29.99
€ 3.70
$ 16.50
$ 999.00
PinSound
$ 22.50
$ 29.99
$ 28.00
$ 69.99
$ 50.00
$ 99.99
$ 59.99
$ 24.99
Lee's Parts
KAHR.US Circuits
$ 219.99
PinballBulbs
