New! Dark mode!
(Topic ID: 205592)
Lifted (Sort Of) Arrow Inserts
By John_In_WI
2 years ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Mitch
#1 2 years ago
Recently picked up a Williams Blackout. Many of the arrow inserts are lifting at the pointy end only. If I apply enough pressure I can push the tips back to being flush with the PF.
The PF is pretty much shot and my long term plan is to install a Hardtop, if they ever do them. For that, the PF needs to be sanded and I think the raised part of the inserts are too high to simply sand them flush.
My question is, do I push them flat as is and attempt to re-glue them, or pull them out and re-glue the whole thing?
#2 2 years ago
IMO, you're going to expend just as much effort to try to re-glue just the end as you would the whole thing, and still run the risk of it getting heaved up again. I would pull them and flush-clamp them and then glue them.
#3 2 years ago
Quoted from John_In_WI:
I would take them out completely, clean up the area, replace and reglue.
#4 2 years ago
Your inserts are probably cupped and warped. Pretty common on
Blackout and Firepower.
#5 2 years ago
Remove inserts. Lightly heat with heat gun to flatten. Re glue
$ 11.00
$ 14.00
$ 12.00
Siegecraft Electronics
$ 50.00
$ 40.00
Arcade Arts
$ 369.00
$ 19.95
$ 48.00
$ 249.00
PinballBulbs
$ 9.95
$ 64.00
Lighting - Under Cabinet
$ 48.00
$ 125.00
pinballmod
